Question Is 700 watts for this system too much?
Sep 6, 2019
7
I have vengeance 16gb 3200 mhz ram, radeon rx 570 OC, and ryzen 2600, I'm also looking to overclock CPU and get an H100i corsair. What wattage is cheapest but also very safe?
No such thing as cheap and safe, a good quality 550W, which I'd recommend for that build is going to cost around $60-70 (USD).
PCPartPicker Part List
Power Supply: Corsair TXM Gold 550 W 80+ Gold Certified Semi-modular ATX Power Supply ($69.99 @ Newegg)
Total: $69.99
Generated by PCPartPicker 2019-09-06 10:35 EDT-0400
Cheap ones do this...
View: https://www.youtube.com/watch?v=LTVEtr14FEA
Okay well right now I'm looking at the evga 700 watt 80+ none modular pcu. Should I go with this? EVGA 700 BR 100-BR-0700-K1 700W ATX12V / EPS12V SLI CrossFire 80 PLUS BRONZE Certified Non-Modular Power Supply https://m.newegg.com/product/9SIA0ZX7WE5772?ignorebbr=1&m_ver=1
No, it's a pretty low end unit. A higher end 550W unit would be much better then any low end 700W+ unit.
What is your max budget for a PSU? If possible I'd highly recommend the Seasonic Focus Gold, it's excellent quality and has a 7 year warranty. The Plus version is fully modular (easier cable management) and has a 10 year warranty. The TXM I posted above is really good as well.
My biggest is trying not to go over $90. I didn't know evga was pow end (I'm new to the community) I'll check out the one's you posted.
Would this be fine it's great for the budget! CORSAIR VS Series, VS550, 550 Watt (550W), Active PFC, 80 PLUS White Certified Power Supply https://m.newegg.com/product/N82E16817139229?m_ver=1
