F fordongreeman Honorable Nov 5, 2017 415 3 10,785 Oct 5, 2022 #1 Is a 1050W platinum-rated thermaltake power supply enough for an RTX 4090?
lvt Honorable Apr 19, 2021 3,683 604 10,940 Oct 5, 2022 #2 fordongreeman said: Is a 1050W platinum-rated thermaltake power supply enough for an RTX 4090? Click to expand... The minimum PSU wattage for the 4090 is 850W (recommended by nVidia). So a 1050W PSU should be ok. If budget is not an issue, you probably want a 1200W PSU for a complete peace of mind. Upvote 0 Downvote
Vic 40 Titan Ambassador Oct 22, 2013 20,885 994 87,990 Oct 6, 2022 #3 Depends on the other parts as well. Like what cpu, there can be quite a different powerdraw between latest Intel and AMD cpu's. Reactions: RodroX Upvote 0 Downvote
RodroX Honorable Aug 4, 2019 3,318 1,061 10,290 Oct 6, 2022 #4 The embargo day is right around the corner, perhaps it will be wise check reviews. Reactions: Vic 40 Upvote 0 Downvote
