Is a 144HZ monitor worth it ?
if your gpu is capable of delivering 120+ fps, then the gameplay will be smoother. You will notice the difference, no doubt. If your gpu cant do 120 fps, then dont bother, because you wont be able to enjoy the full experience of such a monitor.
I should say this... before i had 144 hz monitor, i didnt think there will be much difference, but after having it i can't go back.
the 3d difference between 60 hz and 120-144 hz is muuch more observable indeed.
PS : professional games often suggest having as many fps as posible, even by lowering quality. they would not recomend 120 + fps if they had a 60hz monitor.
No no no,I'm not talking about the 3D feature.I'm talking about games,how would it affect the smoothness of the games ?
Bouncedk is incorrect. There is a huge difference between 60hz and 120 or 144hz when it comes to smoothness and feel. Most die hard gamers understand this and perfer this. The problem that most people have is that they buy a 120hz/144hz monitor and they run a crappy video card that can't run high enough fps in the games they play to match the hz rate so they don't feel the benefit of the 120/144hz monitor. If your a 1080p gamer playing the latest games, you better have a really good video card or sli setup that will allow you to average at a minimum 110-150 fps in all your games otherwise don't buy the monitor.
Is GTX 660 Ti SLI enough ?
O yes, a 660ti sli setup will be just fine for a 120/44hz monitor with todays games. I used to run a 670 sli setup with the same Asus 144hz monitor so I have a little bit of knowledge about it and plus that setup ran great! So, with that being said I feel like the monitor purchase would be a good choice for you because your going to be able to average pretty high fps in just about any game you play. Enjoy the monitor and let us know how you like it when you've had some time to play on it for a while.
i have an asus g75v with a gtx 670m card is there any way i can make this setup be competitive eg buying a monitor or updating to windows 8 to improve to latest direct x ?
and how far behind am i from a top of the line gaming rig ? i run bf4 on low so i can get as fast as possible
The refresh rate most certainly DOES matter. That's the reason why a 120hz HDTV is better than a 60hz one. There's a problem with 60hz monitors called motion blur that causes fast moving objects on screen to appear out of focus and jaggy. The monitor can't redraw the moving object fast enough to keep up with it's motion. This manifests itself on television a lot in sporting events, like when a running back has the ball and is running it in for the TD. He is moving faster than the television can redraw him so he appears blurry at 60hz. At 120hz, he is crystal clear from the start of his run all the way to his victory dance in the end zone. Action films with a lot of running around and fighting also tend to suffer from this at 60hz. It's no different in fast paced games where there are a lot of objects whizzing around on the screen at the same time. 144hz monitors can handle the redraw necessary for fluid motion, where 60hz monitors stumble.
Hi
I have one of these monitors and an Nvidia 680 video card.
I can tell you that there is a noticeable difference in the smoothness in games over my old 60 Hz monitor.
It's not just that you see more frames because of the fast refresh rate but it does actually effect the way that the animations display.
It actually seems to slow things down, but in a good way, I haven't noticed that it effects timing in games, but it feels like you get more time to think, if that makes any sense.
Mike
What GPUs can run 1080p at 144 fps?
NVIDIA series would be 980 and up. AMD series would be 290/390 and up. I was able to pull 144 fps with my old 980 on the ASUS VG248QE. Then I upgraded to the 980ti and I upgraded my monitor to the ASUS ROG Swift 1440p G-Sync monitor and my 980ti can handle 144 fps (granted the game has to allow 144Hz).
Very Well said.
Very Well said.
Why aim so high? 110-150 Hz would be very good, of course, but even 85-110 would be a huge improvement. Why do I think so?..because I use to run a CRT at 85Hz, and it was way better, and easier on the eyes, than even the standard 72Hz of the time. Perhaps an extra 13-25Hz seems trivial but, I assure you, it's not. Of, course, the higher the figure, the better the bang for the buck, but you don't need to be hitting 110Hz+ to make the headroom worth having.
Yes, the type game that benefits from higher refresh rate the most is first person shooter (CSGO).
I owned ASUS VG278HE for more than two years and I loved it. You can play games with 144fps, feels silky smooth when action is intense. But you need a good card though. I paired it with 980Ti, so the point is if you have high tier card, IT IS WORTH IT :)
thanks
I just bought that monitor 4 days ago. After a lot of researsh, this vh248qe was the best choise for me... i have it with a strix 980 ocd to 120% geting 1476mhz and memory to 8000mhz and 6600k ocd @4.4, with cs go u get like between 300 to 450 fps more than enough. I play it with vsync triple buffer looks great! By that in that particular game u only use like 50% of the card of course and battlefield hardline u get more 100+fps in ultra. So go for it in my opinion. U will love it!
congrats on getting da monitor and thanks 😀
