Is a 300w power supply adequate for an i7 ?
swedeintheus
15
Hello,
I'm uprading a Gateway DX4320-02E with a new mother board, an I7-2600, and 32GB of ram. The PC has a 300watt PS. Will this be enough or does this need to be upgraded to? I'm running 2 internal HD,s and one external HD as well as an CD/DVD drive.
Hi HEXiT:
The PC is used exclusively for music production, which uses a ton of RAM and runs the proccessor quite hard. However, the most demanding video it will ever run is Quicktime movies, and the production programs (Finale & Cubase) don't benefit from special graphics cards.
Thanks everybody, however, I do have one more question, if I may. Will I have to re-install all drivers and such, or will a new MB+proccessor it "plug and play" given that I'm keeping the original hard drive?
that makes more sense i have a m8 who also does music production... his system doesnt have anywhere near that amount of ram though...
he also dual boots with hackintosh which allows him to use the mac based software which his collage uses.
maybe you should look into that side of things as he swears by the ease of use of the mac apps
Hi HEXiT:
If you do mainly audio recordings, 4-6 GB is enough, but with midi/VST, and adding effects, 16-32 GB is what you need to be safe. I have 8 GB now, and do I run out from time to time. Memory has gotten so inexpensive, that I think it would be silly not to load up to the max, and never have to worry about it.
