I have a Corsair RM550x, which is a modular PSU. I was having trouble starting my PC (details below), so I tried using a different CPU cable from another PSU. I thought that if it fits, it should be ok. However, as soon as I started it with the other cable, my PSU made some sound and never started again. Using a multimeter, I found out that the PSU's original CPU Cable, a Corsair Type 4, had the top row of the PSU connector mapped to the bottom row in the motherboard connector and vice versa. However, the cable I used had a different layout: the connectors matched top to top and bottom to bottom. Since the rows esentially correspond to 12V and Ground, respectively, the end result must have been that I flipped the current direction to the motherboard.. could this have really destroyed my PSU? Doesn't the motherboard or the PSU have diodes preventing accidents like this or anything? I am asking because I sent it over to warranty and the people there said it is not fixable and they could refund it.. however, I feel guilty getting a refund if I was the one who destroyed it in the first place because of my stupidity.
Details on why my PC would not start up: I would get the GPU Debug LED on the motherboard lighting up very often, followed by beeps. Turns out the main problem must have been that my GTX 1070 needed a FIRMWARE UPDATE 🙂oops
for supporting DisplayPort 1.4.. after installing that, I am now (using a different PSU) only rarely getting beeps (which might indicate there is indeed some problem with the GPU or maybe motherboard, but I didn't really bother with it..).
EDIT: Should it matter, my components are: an Asus GTX 1070 Turbo GPU, a Ryzen 5 1600 CPU, an MSI B350 Tomahawk Motherboard, my case has 5 fans and I have a DVD/RW unit, an M.2 SSD, a SATA SSD and 2 hard disks.
