[SOLVED] Is it possible to adjust what angle my laptop lid triggers sleep mode?
Nov 9, 2021
Hello everyone, my laptop triggers sleep mode at a very steep angle, I often close the lid slightly to see the ports in the back and it goes into sleep mode.
I have a Lenovo legion 7i. I am curious as to what merchanism is used to trigger sleep mode. Possibly a conductive material around the hinge that changes resistance as it stretches (lid is closed)?
How would I change the angle at which sleep mode is triggered?
Is there some setting somewhere? Or could I somehow change the trigger voltage if it is a variable resistance mechanism?
Thanks in advance for advice/insight
Simply put, the answer is no, since the hinge on any laptop isn't designed the same. Some have to be really close to the base while some initiate a little higher than that but the mechanism is the same. If you didn't know it's a magnet found either at the front of the laptop, where the laptop's lid clamps or the base, where the hinge is.
