Is it possible to check if CPU's memory controller is faulty
WodaPoParowkach
6
I recently bought second-hand Gigabyte Z77X-D3H with Core i5-3570K processor with stock cooler (already mounted by seller). It all seemed to be okay but when I launched resource-demanding game my computer started to act weird. Random crashes, freezes but it was not very frequent so I didn't expect anything bad. But when I tried to play GTA V it became literally unplayable. I mean it performs very well, I have around 50-60 fps on utlra settings but it always freezes shortly after launch.
I launched Windows Memory Diagnostic Tool and it detected errors. I was sure it's fault of my brand new memory sticks I bought 2 days ago (1866mhz CL8) so I swapped them with old ones (1333mhz CL9) that I used successfully for a few years and launched memory diagnostic tool again and... it also found errors. GTA V also crashes in the same way on these old sticks as on the new ones.
I am almost sure now (but I will soon check these new sticks on other computer to be 100% sure) that it is a fault of motherboard or memory controller in my CPU. How to find out what exactly is wrong here? I don't want to buy new motherboard when I'm not sure if it's not a CPU fault... Please help me I'm stuck here.
My OS is win 8.1 with the newest updates installed.
It's very possible that the other memory sticks are bad too. Just removing them from the PC can cause damage from static. I don't think there's any way to test the memory controller. You would just have to put a different cpu in the motherboard and see if the issue is resolved. Bad memory sticks are a very common problem though. I've ran into that issue more times than I can count.
Thank you for your answer swilczak. I have just put these new sticks into a different computer (also with 3570K nb) and ran test and it detected no errors. Also I am always very careful not to damage electronics I touch with static charges.
I don't think it can be memory's fault. It's sad to hear that it's not possible to test CPU's memory controller itself.
