Is it possible to use 2 monitor without graphic card ?
vikbot
107
I want to buy 2 Full HD LG monitor (23MP67HQ) which has 1 VGA and 1 HDMI port. My question is if 1 monitor is plugged over HDMI then is it possible to connect another one via VGA ?
Let me explain -
Monitor 1 - Motherboard's HDMI port.
Monitor 2 - Motherboard's VGA port.
I don't have GPU and not willing to buy one as of now. So, I'm looking to plug those monitors with motherboard's built-in HDMI and VGA port. Is it possible to use them without graphic card ?
My motherboard is Gigabyte GA Z97M-D3H.
DVI->HDMI cable
http://www.amazon.com/AmazonBasics-HDMI-DVI-Adapter-Cable/dp/B00L3KNZZ8
$6.49
Yes, it will work.
Ignore the D-Sub port.
Yes, your motherboard and integrated Intel graphics supports up to three monitors at once. You can use the HDMI port for one monitor and use the VGA connector for the other. You could also buy a DVI -> HDMI cable to connect the 2nd monitor if you prefer not to use VGA. VGA @1080p can sometimes be a little bit fuzzy but it still works.
R you sure bro that a DVI converter will work with my motherboard ? it says "The DVI-D port does not support D-Sub connection by adapter" I don't know what that mean.
DVI->HDMI cable
$6.49
Yes, it will work.
haha...click on that, and I see:
"You purchased this item on August 22, 2012"
Yes, it works...:)
