Reignhart :
i've bought a gtx 660 which requires a 6 pin connector and also a molex but I have a slight problem the graphics card arrives within this week while the molex arrives with the next 2 weeks and I can't help but ask if it is possible to use the 660 without the molex
GPUs that have both a 6 pin PCIe power connector
and a 4 pin Molex power connector typically require only one of the two connectors to be populated. The presence of the Molex connector is for use with power supplies that either do not have a 6pin PCIe power connector, or do not have enough of them. This was a common configuration in the early to mid 2000s, but I haven't seen it for a very long time.
The only way to be sure is to plug it in and try it with whatever you happen to be able to connect at the time. If the GPU isn't receiving enough power, it won't boot. However, nothing will be damaged.
