Hi,
So someone has told me who doesnt know anything about a pc build that you can not use an eletric cordless screwdriver inside a pc build. There reason to this is because it has a battery inside which can damage the PC. Is this true or not?
My point of view is that you can use an eletric cordless screwdriver only if you know what your doing like not overtighting the screws etc. But there shouldnt be any other danger right?
And yes we should use manual screwdrivers as it can be safer in terms of damanging the screws inside the build. But for the sake of this argument, can you or not use a cordless battery screwdriver to build the whole PC?
Thanks
Thanks
