Is my cabinet worth for handling geforce gts450 and corsair gs600 psu
adilkm
28
i have an iball i6363 cabinet which is a normal pc cabinet. i wish to upgrade mypsu to corsair gs600 and i hav a geforce gts450 graphic card. Is my cabinet enough or whether i have to change my cabinet...??
Rugger
Splendid
The GS600 is a good PSU but it is overkill for a system with a single GTS450. A good quality 400W PSU with at least one 6-pin PCIe power connector and 24A on the 12V rails would be sufficient. The Seasonic S12II-430 is more than sufficient and is a great PSU: http://www.flipkart.com/seasonic-s12ii-430-watts-psu/p/itmd5xz5bzevdbzp?pid=PSUD5XZ4PQNBPMES&ref=f81eae09-995c-4119-902e-2beeb15341ea If you intend on doing an SLI with the GTS450, then the SeasonicS12II-520 would work great: http://www.flipkart.com/seasonic-s12ii-520-watts-psu/p/itmd5xz5hzvzt9cx?pid=PSUD5XZ4KFH65H9E&ref=1ec79da1-f67e-47ee-b6f9-7919b5a2dd0e Both are also less expensive than the GS600.
Rugger
Splendid
The only Coolermaster PSUs that I would even think of considering are the Silent Pros. I've stayed away from crappermaster since they started using liar labels on their Extreme Power series of PSUs; any company that inflates ratings on their product so they can charge more money will not get my business. The Seasonic S2II-520 is a much better quality PSU than the GS series of PSUs from Corsair; if they are even close in price you should go for the Seasonic. I'd pay extra for the two extra years of warranty and higher quality of the Seasonic.
adilkm
28
but is the Seasonic S12II 520 Watts PSU possible without an SLI on a single gts450....??
adilkm
28
i'll go with the Seasonic S12II-520... Thanks a lot for helping me... :)
