[SOLVED] Is my motherboard compatible? pls help
sp1ga
24
i just went on to my motherboard site, and searched compatible ram and it didnt come up?
doesnt really matter.Your motherboards max speed of 2666mhz ram,and you are buying 2666mhz ram.Your mobo can have up to 32gb of capacity,you are ordering 16.I have had cases where RAM isnt showing up on motherboard manufacturers site,yet they worked perfectly
Hi I am just about to buy some new ram tonight, and I was hoping someone could quickly check this for me as I am a bit unsure, I was wondering if my mb is compatible with this ram
my motherboard: h310m pro-m2 (ms-7b28)
the ram i want to buy: https://www.amazon.co.uk/HyperX-Fur...eywords=ram+16gb+2666hz&qid=1594951836&sr=8-7
i also have seen this ram i might also buy so please could you tell me if this is compatible also!!!
https://www.amazon.co.uk/dp/B0123ZC44Y/ref=dp_cerb_2
its compatible with both RAM
Reactions: sp1ga
