My computer is pretty new. Just build it maybe 2.5 months ago. It's got a P55-GD55 from MSI, an i5 cpu (can't remember which), 4GB of ripjaw RAM, etc etc.
Anyways, today I bought a gigabyte 5830 video card to upgrade my 9800GT. I popped it in and fired it up.
SIDE NOTE: ... but an important and somewhat shameful one. I changed out this card in my room, on carpet. I stood on a skateboard if that has any chance in hell in making any kind of static difference. My case is painted black so I figured a static wrist strap was irrelevant. I was *very* careful to not touch my motherboard or the face of the videocard (only the outside edges).
anyway, I started up my computer and this is what happens:
lights on, fans spin up -- but only for about a half a second, then it shuts off. It does this repeatedly until I shut off the power supply. I've used a power supply tester to verify the PSU is good.
I swapped everything back to what I had before (unless I missed something minor, which I am certain I didn't) to no avail. The final step to my adventure I removed the motherboard from the case, set it on cardboard, hooked up the PSU (both connectors) to the motherboard, removed everything except the CPU from the mobo and it does the same thing. I even tried removing hte CMOS battery for about 10 minutes. No success.
Am I screwed? I fear the answer, obviously.
EDIT:
My PSU tester doesn't test the extra 4 pins that are combined to make 1 big connector, and it does not test the other/separate 4 pin connector that goes somewhere else on the mobo (for this mobo, on the north west side)
EDIT:
