[SOLVED] Is my Sentey ERP650-PS enough for my 1060 and Ryzen 5 1600 and futures upgrades??
Oct 11, 2019
I have been using this PSU for already 2 years with:
*GTX 1060
*Ryzen 5 1600 (planning to upgrade to a 2600 or something better)
*A320M-K *Two 8GB HyperX Predator DDR4 8GB 3200MHz
*One 24'' Monitor, one 17'' and planning to add a 25'' 240Hz.
One SSD and one HDDCD/DVD RW
*Three 4'' Fans
I think my system is working perfectly (I never had a problem) but I am wondering if I would NEED to upgrade my PSU to something like a Corsair RM550 or so because Sentey is not a good brand. I've heard that the main problem with these PSUs is that some units came already "broken/badly factored" but mine is fine.
IF WORST CASE SCENARIO OCCURS what will happened? Will my GPU, CPU, RAMS, Motherboards burn out? Or I only would need to replace the PSU?
Yes you should upgrade to a better psu. Your current unit is low quality. Worst case scenario it fails and takes the rest of the system with it.
