Well, you might be able to physically get a AM2 chip into a 939 socket, but it won't work. AMD has alternated from 940 to 939 to AM2 with a 940 pattern but different internals. If nothing else, a tap with a hammer would make it fit, but then it still wouldn't work. Besides the pin difference, there's also the matter of the different memory controller.
did a search... didn't find the answer right away... (mebbe based upon my search criteria) so I asked the question again because I needed a prompt reply.
So, thanks for the prompt reply, and I promise I won't ask it again 😀
So basically what happened was AM2 took S939 out back, with a rifle in hand and next thing you hear is a gun blast. AM2 says that S939 is now on a farm with all the other sockets that have been "retired".
actually pauldh, was talking about how ASrock, had a motherbaord that could use an adapter board that would allow an AM2 processor and DDR2 memory [i think] to be used with a socket 939 ASrock motherboard.
But you still cannot fit an AM2 on a 939, and expect it to work..........
When did AMD start using Zalmans for their stock coolers? I remember when AM2 came out, people were upset that AMD changed the mounting for their sockets. S939 uses two screws, while AM2 uses four. The heatsinks might be the same, but you need different mounting hardware. You can't just take a stock S939 cooler and put it on an AM2 board.
According to this thread, the socket 939 heatsink will fit on the AM2 socket.
But he never posted back with success. I don't think he should use that HSF anyways, there is a difference in heat output in a 3700+, and a dual core 4200+.
As you can clearly see, the mounting bracket is different. If they changed the bracket, I'm sure they changed it so that you can't mount the 939 heatsink on the AM2 bracket.
