Is the Corsair LPX 16GB DRAM 3000MHz C15 for Systems 16 DDR4 3000 MT/s (PC4-24000) DDR4 3000 CMK16GX4M2B3000C15 compatible wit
It is, I think.
Go to the corsair ram configurator and enter your motherboard.
You should see your kit on the supported list.
G.skil has a similar app.
For quad channel operation, you will want a 4 stick kit.
But, a 4 stick kit will be more expensive than a 2 stick kit of equal capacity.
You can use single channel, dual channel or quad channel with X99 motherboards.
