Question Is there a way for me to store a PCIe card inside my laptops 2.5” bay?
May 14, 2023
9
I’m trying to find a way to add FireWire to my laptop. I’m too poor to buy a new laptop with FireWire. I’ve read old forums where people have used an M.2 to PCIe riser, then connected a PCIe FireWire card. But I don’t want it external, I want internal. My laptop (Acer Nitro 5 AN515-54) has a 2.5” bay that’s empty. Could I potentially store a PCIe card inside of there and then use a Dremel to cut a small hole in the casing to allow a short FireWire male to female cable to poke out?
A laptop does not have the internal space for a PCIe device.
In the empty 2.5" bay? There may be space, but not for any connector.
And then dremel a hole in the case?
Why do you NEED a FireWire connection?
My mixer only connects to a computer by FireWire, so that’s why I need it.
Is there any way that I can manage to connect it since my idea won’t work? My laptop doesn’t have Thunderbolt either, so that’s not an option unfortunately.
Sorry, but no.
I have no idea of how to merge these two completely incompatible devices, apart from the external connection thing you don't wish to use.
Sorry, but no.
In that case, how do I go about fixing this up externally? I know nothing about external PCI cards for laptops.
