[SOLVED] Is there a workaround to the ASUS VG259QM's Input lag when running @ 60hz? I'm really struggling deciding between it and the ViewSonic XG2431
dylof
4
I want the 240hz they offer because my PC will be able to run less demanding games very well. But I also want to emulate older games which may be locked to running at 60hz. The VG259QM has really bad input lag when connected to a device/program running at 60hz according to rtings.com.
I'm curious if there is a workaround to this. I'm also hoping I can get feedback from people who have used one/both of these displays. Thank you.
Frame rate isn't the same as refresh rate. Leave the refresh rate at optimal setting and if game is 60fps locked then that won't affect refresh or input latency. If were to change refresh itself then maybe.
Latest posts
