Is there any way to repair my hard disk ? Kindly help
vikbot
107
As you can see one of my hard disk is near to it's death :pfff: Windows is also showing warning message again and again. Anyway, is there anything I can do to repair it's bad sectors ?
Hi there vikbot,
Have you backed up the data stored on the drive? In case you haven't done that, it may be a good idea to do so as the drive can fail at any time.
I don't really think you can repair the bad sectors.
One thing you can try is to use some tool in order to write zeros on it. After that, you can retest and see whether you will get similar results.
Cheers,
D_Know_WD
vikbot
107
Ohhoho ! But Thanks for your reply bro :) Any software you recommend to write zeros on it ?
Similar threads
