So I've always had this wire sticking out in my room and haven't bothered it until now. I'm planning to build a pc and I'd rather want an ethernet connection instead of buying a wifi card. This is an ethernet port right?
can't be a phone jack because there's two right next to it....
When I tried connecting to it using my laptop, it doesn't work. My modem is in the bonus room which is just right outside my room. I've googled many times and found that there should be a 'hub' to activate ethernet wall ports but really i couldn't find anything even in the basement closet where our power switches are. Then I wondered if this would be it.
That hole at the top, that's where it goes to my room. Then there's also a lose phone cable here... Notice that there's two wires in the ethernet plate. One of them is the wire that connects to my ethernet wall jack and the other one is connected to another wall jack in the same room(of this). So I was thinking, 2 slots for 2 ethernet ports? If I connect these two slots to the modem using an ethernet cable, would the two wall jacks be active? Oh and my modem is in the other corner of this two port jack thing... so if my guess is right, I might just run a long ethernet cable from my modem to this. Also there's only two ethernet wall jacks in the whole house....and there's also a coax wall cable right beside the two port plate. So i can't help thinking that this area should've been where the router should be...So it's highly likely that my guess is right? you connect these to the modem to activate the other ethernet ports?...
