Is this a problem with my hardware?
tofui32
8
I upgrade my gpu To Sapphire RX560 2g (45watt), my pc spec
core 2 quad q9550,
500w psu,
8gb dual channel ram,
mobo gigabyte g41m-combo
1tb hdisk
when i open app, doing benchmark, its stable, but when i play game after a few minutes it crash and not responding, need solution pls
benchmark prime 95, furmark.unigine valley, game i had problem crashing ithink all game with nice graphic my pc game warframe, fallout 4, csgo all this game had a crash problem, except 1 game mincraft its not crashing
I use HD6670, memtest86 and windows memtest pass
So if you have an AMD graphics before it can't be any left-over NVIDIA drivers giving problems. if memtest86 is happy, then it isn't a memory issue. We are running out of possible explanations. It is either a software issue internal to windows. Which is possible. A temperature issue in the case or a power supply issue. Have you tried it with the side pannel off the case to provide extra cooling air?
i always run my pc with side pannel open, itried change psu, using 2 psu but same
That probably eliminates temperature. You should double check the temps with HWMonitor or similar just to be sure. Really there is not much left except a software problem internal to windows or your motherboard. It is a pain, but if you haven't done a clean windows install in years, that might help but really, I have no definite explanation.
huff maybe what sapphire says is true i must upgrade my hardware, i have clean install windows, temp no overheating all below 70 C
