[SOLVED] Issue with graphics card shutting down while in use
Dec 28, 2019
Apologies if this has already been answered but couldn’t find anything like it.
I’m having an issue where my new Vega 57 graphics card will cut out while in the middle of running. I.E: I will be typing away at a word document and the screen will just suddenly go black.
The issue occurs irrelevant of the workload on the Graphics card and I do not believe is the result of overheating. I have checked the settings for both the main PC and the Card itself. An interesting note is that audio will continue to play after the video cuts out hence why I believe it’s the graphics card.
Furthermore the cards fans will spin up as soon as it cuts out and for this particular card (MSI airbreather) it has lights along the 16pin connector which flicker depending on power draw, when the card cuts out these lights turn off completely.
Any ideas for what could be causing this or is this just a card defect?
Edit: system details:
CPU: R5 2600X
Motherboard: Aorus Elite B450
SSD: 1tb Samsung 860 Evo
Hard Drive: 1tb WD blue
PSU: 750W Corsair Tx750M 80+ Gold
GPU: MSI Air Boost Vega RX56
RAM: Corsair DDR4 3000MHz 16gb
From the description I would have said power issues but I can't be sure without being there and checking myself. You can do the following:
