Good morning all, I am having a few issues which I was willing to work around until recently when I believe it is more extensive than I had imagined.
Several months back I upgraded my PC, purchased an i5 9400, Gigabyte Z370P D.3, 16Gigs DDR4 3000 to go with my Radeon R570 that I already had.
The first issue I ran into was the 9th gen compatibility, so I updated the BIOS to version F10 which supports 9th gen so no issues there.
However I could never get the computer to post with the GPU in PCIe 16x (Slot 1). I threw it into the 3rd slot and it posts fine, I cannot remember if I tried the 2nd or not, but its in the 3rd posting fine. I also have a wireless NIC in the very first PCIe 1x Slot.
Fast forward to yesterday, I purchased a Mushkin Pilot 500GB M.2 2280 PCie Gen3 4x NVMe SSD. The bios will not recognize it. I pulled all my sata drives, nothing. Pulled the Wireless NIC, nothing. The only thing I have not done is pull the GPU, from PCIe 16x Slot 3.
I have changed every BIOS setting I could possibly think of to try and recognize the SSD and nothing. It does not show in the NVMe Peripherals section, the SATA SSD Section or the Boot Device section.
I had just built a Gigabyte Z390 PC for a friend with a 256GB Mushkin Pilot with no issue, and even with my Mobo being a Z370 it should work I know its supported.
I am starting to think that my Mobo is defective with the top PCIe 16x slot not posting, however I wanted to get some input first if perhaps I did something wrong with the video card install, and then find out if there is something that is also causing the M.2 PCIe SSD not to recognize.
Thank you
Thank you
