Javascript problem....
Ganj
17
A client just brought in a rig and says everything works fine just that java wont work.
I verfied this and it is exactly the case,as soon as I try and open a page that uses a javascript it wont work,machine still runs and everything works just whatever has java wont run.Could it be a Win XP problem?Cause according to my boss Win XP was recently installed on this rig and previously with Win 98 SE it worked.Its using Java 2 v1.4.2_03
We have tryed installing Java 2 v1.4.2_01 and it still does the same thing.
Am I on the right track here with these java versions?Someone plz help this machine is urgent
Btw hardware specs are:
P3 900 mhz (Coppermine I think)
ECS P6BAP-A+
256 MB PC133
TnT2 M64
SoundBlaster Live
Integrated 56 modem
<P ID="edit"><FONT SIZE=-1><EM>Edited by Ganj on 02/11/04 11:54 AM.</EM></FONT></P>
If you're using Internet Explorer to open that page, you may want to check that 'Enable Javascript' is checked in the Options menu. Try that ...
Gary Hendricks
<A HREF="http://www.digital-music-guide.com" target="_new">www.digital-music-guide.com</A>
That was the first thing we tryed,in facts thx to that I know what version of java it is.Plz anyone else think they can help out?
Does IE even use a third-party VM? I don't think so. IE problably uses microsofts regardless of what VM you install. So the problem is probably IE. I would try installing another browser. I recommend Opera. It works fine with SUNs J2RE (Im currently running V1.4.2_03).
<i><b>Engineering is the fine art of making what you want from things you can get</b></i>
Wrong. In fact Microsoft legally can't support/supply their own VM any more. If you go to their site they tell you to get it from Sun. See <A HREF="http://www.microsoft.com/mscorp/java/" target="_new">this page</A>
<pre> \|/
jlanka (. .)
___________oOOo_(_(_)_)_oOOo___________
</pre><p>
If you still want/need MS VM for XP you can still get it fairly easily. Just do a search on the internet (Google found several quickly for me) for MSjavx86.exe.
Once you have the MS VM windowsupdate will update it.
