Jumpy games, Framerate problems, please help
black3421
5
I've recently made a new i7 build with a AsRock Extreme 4 gen 3, nvidia 560 GTX , 1TB WD caviar blue, 8 GB of GSkill ram and a coolermaster extreme power plus 700 watt.
Everything run fine at this point in time, Skyrim and Saints row 3 ran at at least 30 fps.
However, I recently changed the mobo for a gigabyte z68xp ud3r, and the gpu for a HD6870.
Since then, games have been jumpy, but it's usually unrelated to framerate. I get 70 fps in Dirt 2 and Fallout new vegas however it often "jumps" slightly while maintaining 70 fps. :cry:
On another note, Skyrim and Saints row 3, which ran fine on the 560 GTX, now have horrible framerate issues.
I've googled this and it does appear to be a common issue with ATI gpu's, but my other pc with a 6850 runs everything fine.
I think this would probably be a gpu issue but seeing as everything runs fine on a 6850 and I've just changed the mobo perhaps it could be something else?
Any help would be much appreciated.
You did it with that tool? I wouldn't trust doing it manually. This could possibly be a GPU issue, but I wouldn't expect it to work in some games but not others if there were a hardware problem.
How are your temperatures under load?
black3421
5
Alright, I wiped all the drivers and re-installed them, and the jumpiness seems to be gone. However, whilst playing dirt 2, my gpu got up to 75 degrees. Is this normal?
black3421
5
The CPU temp didn't get above 58 degrees.
The case ventilation is great, a 20cm fan at the fron, 14 cm at the top and water cooling.
However, I can't stop the water cooling from running on full, it's a corsair h60. Any ideas?
It's always running at 4300 RPM.
