G
Guest
Guest
Archived from groups: alt.comp.periphs.mainboard.asus (More info?)
I just built a new computer using the K8V SE motherboard, Athlon
3200+,
and set up a Raid 0 using the Promise 378 controller with two WD80
Sata
HDs. Everything works great, including the onboard SoundMax but when
I
insert the Audigy ZS Sound Card into any of the PCI slots and disable
the onboard sound, I get an "No Harddrive found" error on start up and
can't boot.
Has anyone seen this problem before. I searched the groups and have
had no luck so far?
TIA,
Jim
3200+,
Sata
I
can't boot.
had no luck so far?
TIA,
Jim
