You need (temporarily) to use at least the keyboard as a PS/2 device. On the back panel of your computer there are probably two little circular ports for 6 pins, one each for keyboard and mouse. These ports are always active - your BIOS takes care of that, and Windows always has built-in drivers for them. You could do it either of two ways. One is to borrow or buy a cheap keyboard already equipped with a PS/2 connector on its cable. The other is to use an adapter. This works because electrically the connections for USB2 or PS/2 ports are the same, so the adapter only has to convert pins and wires. It has a socket on one end for the USB connector and the round PS/2 connector on the other. It's cheap at computer shops, or you might borrow...
