Keyboard problem
martinlest
147
Hi. As my original Compaq laptop keyboard had developed many broken keys, I bought a new one (keyboard, that is!). I installed the new one OK, but both shift keys produced a string of numbers and letters when you press them (it happens even during Windows XP installation, so it's not a software thing). Googled the problem, but no joy.
So, guessing the new keyboard was faulty, I got it replaced. Infuriatingly, the second replacement does the same thing, so I guess a motherboard problem (??). Does anyone recognise the symptoms? Anything to be done about it?
Thanks,
Martin
Well i had a problem a few weeks ago with my keyboard working on Bios ect, but when i got on the log in screen it did nothing and all the lights were on, i tried all of the USB ports and it was still playing up, i got fed up with it, i then took out and put in the Bios Battery and it work :S ... i am not sure if this will help u but maybe something to try...
Martin is talking laptop and adam is talking desktop?
If this is a laptop, pull it back out and look at the installation. Either a cable or incorrect assembly would be my first choice.
If all else fails then a portable USB keyboard may be in your future...have you tried that as a test??
Yes, I saw that, but I tried removing the battery anyway. I have reinstalled the keyboard several times now - it's all snu and as it should be, as far as I can see at leastg. (I do have A+ certification for PCs, so don't think I am doing anything silly, though I am not so confident with laptops!).
I wanted to test with a USB keyboard but don't have one - nor does anyone I know, so that's a no go for now I'm afraid. (Not that that would tell me exactly where the error is).
Thanks,
Martin
Any more ideas anyone?
I remapped two keys to function as L & R Shift keys, so the laptop is usable, but be good to know why this silly thing is happening - and fix it. HP/Compaq just told me the machine was no longer underwarranty so they weren't interested..
M.
