Greetings from a noob builder, hope you guys can look into my first one primarily aimed at Photoshop CS5 and Vegas 9. Any input or suggestions would be greatly appreciated!
APPROXIMATE PURCHASE DATE: would like to order by Monday, May 10
BUDGET RANGE: US$ 1,100 (need only: case, CPU + cooler, MB, PSU, RAM, GPU)
SYSTEM USAGE FROM MOST TO LEAST IMPORTANT: Photoshop CS5, Sony Vegas 9, FSX flight sim (no other gaming)
PARTS NOT REQUIRED: monitor, OS, HDDs, keyboard, mouse, spk
PREFERRED WEBSITE(S) FOR PARTS: newegg, microcenter
COUNTRY OF ORIGIN: whatever works
PARTS PREFERENCES: Major, solid brands
OVERCLOCKING: probably, but nothing extreme (fwiw I've never OC'd before!)
SLI OR CROSSFIRE: not planned but would like the ability if needed
MONITOR RESOLUTION: 1920x1200 on a Dell 24"
Currently pre-selected components:
CASE: Coolermaster HAF 932 ATX full tower
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119160
Newegg $139.99
* I prefer full ATX simply due to space. Prefer tool-free, will initially be mounting 4 HDD + 2 DVD
PSU: CORSAIR CMPSU-750TX 750W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS Cert. Active PFC Comp. I7
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
Newegg $109.99
* 750W overkill for below?
* Is this unit ok to be mounted on bottom of selected case and will I have problems with cable lengths in full ATX?
* I take it the PSU would have to be mounted upside down? Any potential problems? (aside from being clumsy with screws)
CPU: I7-930 2.8GHz LGA 1366
http://www.microcenter.com/single_product_results.phtml?product_id=0331303
Microcenter $199.99
* Is microcenter reputable? First time I heard of them was through here and am surprised to see the
I7-930 priced $100 (!) less than newegg. Usually if prices are too good to be true, they are.
COOLING: Cooler Master Hyper 212+
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103065
Newegg $29.99
MB: ASUS P6X58D Premium LGA 1366 Intel X58
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131614
Newegg $299.99
* Any problems I may encounter with above case?
* Will I need any extra cables if I plan on 4 HDD + 2 DVD (all SATA)
MEMORY: CORSAIR DOMINATOR 6GB (3 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Triple Channel Kit
Desktop Memory Model TR3X6G1600C8D
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145224
Newegg: $229.99
* 6GB to begin with, may upgrade to 12GB somewhere down the road
GPU: PNY GeForce 9800 GT EE 1024MB GDDR3 PCIe 2.0 Graphics Card
http://www.microcenter.com/single_product_results.phtml?product_id=0320617
microcenter $99.99
* Main uses: photoshop CS5, vegas 9 (HD from Canon 5DmkII), and Microsoft FSX (the only game I play on the PC)
* From what I gather Photoshop is more CPU+RAM dependent, not GPU. However, Adobe seems to prefer Nvidia and
the above features CUDA. B+H seems to be using this card in their "turnkey" CS4 builds.
* I can't find any good info on GPU requirements for Vegas 9 from Sony
* Don't know how well the card would perform for a game like FSX.
Total cost: ~$1,100
Totally lost on finding suitable GPU and open to suggestions (on everything). I've done quite a bit of research and the only thing currently spinning at 7200 is my head. Hope to reduce costs perhaps by downsizing PSU or different RAM or MB provided any loss in performance is negligible.
I will be running Win7 Pro 64 (have seperate budget for OS + software upgrades) and would like to put something together which will serve me well for the next few years and with room to grow and keep up in terms of features, ie SATA III, USB 3.0, possible SLI or Xfire, CPU upgrade, etc.
To compare... my current PC:
Dell XPS, Core2 Quad 2.4Ghz running WinXP Home 32bit SP3, 4GB RAM, GeForce 8300 GS.
Thanks a bunch !!
Newegg $139.99
Newegg $109.99
Microcenter $199.99
Newegg $29.99
Newegg $299.99
Newegg: $229.99
microcenter $99.99
Total cost: ~$1,100
Thanks a bunch !!
