[SOLVED] Kingston M.2 NVMe SSD is slow, need some help
Hello,
I hope some can help me or give me some advice. I bought a new SSD (Kingston M.2 NVMe NV1 1TB S8H40104) for my Laptop but the new SSD is very slow (around 500 mbps). It's slower than my 2nd SSD (around 2000 mbps).
View: https://imgur.com/3e5ZPfY
I tried already some things like disabling Windows Indexing etc but I don't think it's a Windows problem.
Kingston Manager doesn't read my SSD (detected as "Primary drive, KScode2 Identify failed")
I am scared to buy another SSD (Samsung maybe) just to have the same Issue.
Have maybe someone any advice what to do?
I am using a Asus TUF Gaming FX705DT Laptop with:
AMD Ryzen 7
32 GB RAM
Windows 10 Pro with all updates
Thanks and Regards,
Lukas
Hello,
AMD Ryzen 7
32 GB RAM
Thanks and Regards,
Lukas
Post a screenshot from crystaldiskinfo for this m.2.
Jun 11, 2023
I found my Problem! So dump from my side! I installed Windows on my wrong Disk (SSD) not on the NVME and I was checking all the time the wrong Drive (c:/) :oops::oops:
Thanks Bob for the CrystalDiskInfo tip!
Additional question, how can I exchange all my data from Disk1 to Disk2? Should I use Linux for that or there is some Disk Management OS?
Edit: I found already how to clone/exchange my Disks. Problem is resolved, thanks!
Reactions: Dark Lord of Tech
