Hey
I have a kingston SSD A400 240GB for system drive and a WD10EZEX 1 TB for storage
I got Windows 7 installed and the SSD is plugged in the SATA 3 port
When i first got The SSD i could recognize the difference in boot speed (it was faster obv) then after a couple of months it was back the way it was before the SSD
i also noticed that when transferring files between the two hard drives, the SSD read speed is significantly low
attached screenshots of files copied to and from the SSD
when copying from SSD to WD hard drive speed is around ... 5.65 MB/sec
when copying from WD hard drive to SSD speed is around ... 180 MB/sec
That's definitely not supposed to happen
Also i tried crystal disk mark and the results are also attached but it seems normal
could it be that windows 7 or a certain software is doing this ?
Screen shots links
https://ibb.co/VC391Gn
https://ibb.co/5YVyWTf
Thank you and sorry for long post
Screen shots links
