Koolance Makes Water Block for AMD's R9 295X2 Card
Does it bother anybody else that they put the name on it upside down? It'll be completely backwards in your case, and it seems like every block does the same thing
Because it faces down in the case, backplates are the only things that actually need correct writing.
Does anyone else find it ironic that AMDs most power-hungry, highest heat-producing, GPU is going to be the one that runs at the lowest temperature?
