G
Guest
Guest
Archived from groups: rec.audio.tech (More info?)
Hi all,
I'm hoping someone out there can help settle an issue for me. I am in
the process of building a basic 2-way floor/stage monitor (wedge type,
8"woofer, 3" piezo tweeter with a 6.0 uF cap in series to cut the low
frequencies, woofer running full range)to be used as part of the sound
sytem set-up for a small kids show. I'd like to build in a simple,
effective volume control. My question is will an L-pad of sufficient
wattage do the trick?
Here's my set-up: One old but functional Realistic MPA-80 PA amp rated
at 80 watts @ 4 Ohms. Currently I run a pair of 8 Ohm 2-way PA
speakers in parallel (4 Ohm load). I plan to run the 3-speaker setup
in series-parallel at a 5.33 Ohm load. By my calculations, each
speaker should then be getting about 60 watts of actual power.
On the face of it, I would assume that a 100watt 8 Ohm mono L-pad
would allow me to effectively reduce the output from the floor
monitor. Is this a correct assumption, or will I just burn out the
L-pad? Is there a different switch/pot I should be using instead?
Your input is greatly appreciated.
Hi all,
