Lack of 1 pin in the ATX12V (20-pin) connector. ("19-pin"
Johnny Mnemonic
12
Hi, sorry for my english.
I have Thermaltake TR2 500W TR-500P 24+8+4+6+6/8 pin
(Model: TR2500AH2NFB), ATX 12V 2.3.
And mobo ASUS P8H61-M 24+4 pin
There is a lack of 1-pin in the 20-pin connector in PSU, just a hole. Is normal?
Сan it Damage or affect anything? Or What?
And by the way, is it a reliable model or crap?
We get this all too often.
-5v was removed from the ATX spec many years ago, it's why you have a missing pin and won't affect your system.
Oh, and an over priced, not very good psu, but should do for a low end system
Thanks.
And last cuestion, is 500W PSU (Real 400-420W) OK fo this configuration:
ASUS GTS 450 DDR5
Intel i3-2120 (3.3GHz)
2x Kingston 1333Mhz 4GB memory
1x Western Digital Caviar Blue 500Gb
2x Western Digital Caviar Green 3TB
Old 2004 Year Creative Audio Card
7x 120mm Fans
ASUS P8H61-M
At the place where I currently live, a very hot summer and I can't by a conditioner because i can't put it on/in the building.
And my PC becomes very hot sometimes. So I use 7+ fans and same number of filters.
Here is in the summer usually dusty, smoky, heat. (Looks like Hell, right. :pt1cable: ).
Thanks for spending your time on my questions.
You really helped me. You are the Best 😉
Certainly sounds like it.
Good luck with the build.
PS; I'd do away with the old sound card, onboard has come a long way
