Laptop blank screen problem
tomastalaat
35
my laptop boot up and screen flickering boot logo then on windows log on the screen turn black but i can see light from screen ( when i change screen brightness degree i fell the change it's not seem dead ) also the screen flickering when i make changes to display setting so i can see images but for seconds then go black again when i when i connect external monitor it works well so what's is the problem ?
The external monitor does not work after you uninstalled the drivers because it needs the driver to work the external port. See if you can get it working by turning on the laptop then closing the lid right away and see if the image comes on the monitor.
it was working in external monitor and when i apply display change the laptop screen blinking but when i uninstalled the Graphic card driver and restart the laptop the external monitor don't work so what is the problem with ?
