I noticed my laptop’s cooling fan wasn’t blowing air out of the system as it should, so I disassembled it. I found that it was actually pushing hot air back inside. The fan has a small opening that lets air leak through, and I’m looking for a suitable material to seal this opening. I thought about using some kind tape or putty, but I’m not sure if those two would work well.
Here is a visualization of the above:
