Question Laptop does not automatically connect to WiFi ?
brenski
21
As it says really. We have two of these ASUS VivoBook X513EA (win10) laptops both only three months old. Suddenly last week one of them has decided to forget to autoconnect to wifi at power up. To be truthfully honest, it does (randomly) autoconnect to wifi once every dozen or so power ups. It also autoconnects the very next time after being manually reacquainted with the network.
The device is an Intel WiFi 6 AX201 160Mhz
Here's some of the unsuccessful fixes I've tried: (attempted with all five drivers dated from Apr 2021 to Dec 2021)
♦ Ctrl Panel > Remove device > rediscover > reconnect > restart
♦ Ctrl Panel > Remove device > shutdown . Power up > rediscover > reconnect > shutdown > Power up
♦ Ctrl Panel > Remove device & Drivers > rediscover > reconnect > rerestart
♦ Ctrl Panel > Remove device & Drivers > shutdown . Power up > rediscover > reconnect > shutdown > Power up
♦ Settings > Wifi > Manage Wifi Settings > Forget > rediscover > Select Connect Automatically > restart
♦ Settings > Wifi > Manage Wifi Settings > Forget > rediscover > Select Connect Automatically > restart > shutdown > Power up
Command Prompt (Admin) /Powershell > netsh wlan show profiles > netsh wlan delete profile name="Name of the Wi-Fi network"
♦ Regedit > HKEY_LOCAL_MACHINESOFTWAREPoliciesMicrosoftWindowsWcmSvc > WcmSvc > GroupPolicy > fMinimizeConnections
Ctrl Panel > Devices > View Hidden Devices > remove Microsoft WiFi Direct Virtual Adapter (despite removal it auto reinstates itself - sometimes upto 5 of thes eare showing)
I'm now at a loss. As Toyah used to say: "It's A Mystery".
Any help appreciated.
sorry, i don;t see how any of those questions are relevant. As i said in my OP:
"We have two of these ASUS VivoBook X513EA (win10) laptops both only three months old. "
therefore, as all are constants for both laptops, so invesitgating Windows version, BIOS or router would cloud the issue, surely? if one laptop of two identical laptops is working fine, then windows, bios or router are not the issue?
BIOS = 308
GoP = 17.0.1044
EC = F0062106.209
Win 10 = 21H2
Router = Arris, Virgin Hub 3
BIOS = 308
GoP = 17.0.1044
EC = F0062106.209
Win 10 = 21H2
I'm having exactly the same issues, same model laptop but I have Win 11. Mine was working fine until today. Surely an issue with the Intel device? Again, mine is the same. Bios etc. all same as yours.
Currently having to use my old Acer laptop, hoping Asus/Intel will bring an update out soon!!
I've since read elsewhere that others are having issues and are blaming the last Windows update, suppose this could explain things, just hoping there's an update soon.
