[SOLVED] Laptop randomly freezes and needs hard reset
Feb 1, 2020
4
Operating System
Windows 10 Pro 64-bit
CPU
Intel Core i7 3537U @ 2.00GHz 48 °C
Ivy Bridge 22nm Technology
RAM
8.00GB Dual-Channel DDR3 (11-11-11-28)
Motherboard
ASUSTeK COMPUTER INC. X550CA (SOCKET 0)
Graphics
Generic PnP Monitor (1366x768@59Hz)
Intel HD Graphics 4000 (ASUStek Computer Inc)
Storage
238GB LITEONIT LCS-256L9S-11 2.5 7mm 256GB (SATA (SSD))
I reinstalled Windows, changed the SSD and the second 4GB RAM, but the same problem persists.
It could happen by browsing or not opening any software at all.
Thank you!
Feb 13, 2020
19
4
Since you already swapped out the SSD and the RAM.
I would think that this was a driver issue. Windows 10 is pretty good and installing drivers by itself, but try installing it manually:
https://downloadcenter.intel.com/download/29311/Intel-Graphics-Driver-for-Windows-15-33-?product=81499
If that does not fix the issue then the Built in Graphics might be shot where you are likely looking at replacing the motherboard:
https://www.amazon.com/gp/product/B07PM4141Q/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=r31c-20&creative=9325&linkCode=as2&creativeASIN=B07PM4141Q&linkId=76598ed10321de0f10d2965888bcbbbf
$229 - i7
https://www.amazon.com/gp/product/B07VWTZHR9/ref=as_li_qf_asin_il_tl?ie=UTF8&tag=r31c-20&creative=9325&linkCode=as2&creativeASIN=B07VWTZHR9&linkId=367614280938b584c536f8484b9efd1b
$89 - i5
An i5 replacement board is $89 compared to an i7 board at $229. Depending on how much an i7 means to you would be your cost.
Reactions: gazpacho88
natcha12
259
26
Did you change hardware just before it all started, specifically RAM or HDD/SSD, and what actually happens when it freezes? Screen go blank/BSOD/or literally display just freezes?
Is your HDD light still flashing showing activity after a freeze? If there is activity, test with another monitor and/or cable.
On the start menu, look up "Reliability History". A crash log and a reason why may be there.
Need more information if you want to get to the bottom of this
Feb 1, 2020
4
Hello,
Thank you so much for your response, I really want to get to the bottom of this.
It's been 2 days with no problems until it's started again.
-I formated the laptop, changed the SSD and the extra RAM because of the problems, it has made no difference.
-The screen freezes 95% of the times (and stays like that until I hard reset. The 5% of the times, it goes blue screen Windows "Oops we have a problem", it goes until 100% and stays there.
-The HDD light has no activity when freeze.
-The Reliability History is not very accurate (see picture linked), I remember it froze yesterday and it does not show anything, today it only froze once and it shows 3 events. Most of the times it says "Windows was not properly shut down". Only one time it says "Windows was not properly shut down" followed 1 min later by "Win stopped working", "Hardware error", and "shut down unexpectedly".
This is the report of the hardware problem:
Source
Windows
Summary
Hardware error
Date
‎1/‎29/‎2020 11:05 PM
Not reported
Description
A problem with your hardware caused Windows to stop working correctly.
Problem signature
Problem Event Name: LiveKernelEvent
Code: 117
Parameter 1: ffffae882d024010
Parameter 2: fffff80739c150d0
Parameter 3: 0
Parameter 4: 418
OS version: 10_0_18362
Service Pack: 0_0
Product: 256_1
OS Version: 10.0.18362.2.0.0.256.48
Locale ID: 1033
Feb 1, 2020
4
Yes, I have.
I have tried different things, sometimes when I do something it stops freezing for a few days, and after that, the same problem reappears.
This has happened with hardware (e.g. removing the extra RAM) or with software (e.g. updating a driver).
Thank you for writing!!
I remember having a laptop that did that all the time, once. Have u tried moving files onto another computer and setting up the laptop as new?
Feb 13, 2020
19
4
$229 - i7
$89 - i5
Feb 1, 2020
4
$229 - i7
$89 - i5
Thank your help and information.
It's been 7 days without freezing, I was just writing to you to say that I have updated drivers manually and hopefully this issue will stop and it the laptop just froze again "Windows was not properly shut down".
The laptop cost me $550, 5 years ago, I really want to fix it, but I do not know if it's worth investing that much money on it...
