Hello all,
I have an Acer laptop with Windows 8.1 and recently just had a BSOD. The message with the BSOD said something along the lines of
Kernal Data inpage error. "🙁 Your PC ran into a problem and needs to restart. We’re just collecting some info, and then we’ll restart for you. If you would like to know more, you can search online later for this error: luafv.sys." and one time it was "dxgkrnl.sys".
Another time, I had a BSOD again but the message that time was "CRITICAL_PROCESS_DIED"
I ran sfc /scannow in safemode and it said it found some errors but was unable to correct some of them. After that I ran a CHKDSK /f /r and I have posted the results here:
Checking file system on C:
The type of the file system is NTFS.
Volume label is Acer.
A disk check has been scheduled.
Windows will now check the disk.
Stage 1: Examining basic file system structure ...
Read failure with status 0xc0000185 at offset 0x48af66b400 for 0x400 bytes.
File record segment 290313 is unreadable.
2014976 file records processed.
File verification completed.
6498 large file records processed.
1 bad file records processed.
Stage 2: Examining file name linkage ...
2194086 index entries processed.
Index verification completed.
CHKDSK is scanning unindexed files for reconnect to their original directory.
1 unindexed files scanned.
0 unindexed files recovered.
Stage 3: Examining security descriptors ...
Cleaning up 68 unused index entries from index $SII of file 0x9.
Cleaning up 68 unused index entries from index $SDH of file 0x9.
Cleaning up 68 unused security descriptors.
Security descriptor verification completed.
89556 data files processed.
CHKDSK is verifying Usn Journal...
Usn Journal verification completed.
Stage 4: Looking for bad clusters in user file data ...
2014960 files processed.
File data verification completed.
Stage 5: Looking for bad, free clusters ...
33496931 free clusters processed.
Free space verification is complete.
Adding 1 bad clusters to the Bad Clusters File.
Correcting errors in the master file table's (MFT) DATA attribute.
CHKDSK discovered free space marked as allocated in the
master file table (MFT) bitmap.
CHKDSK discovered free space marked as allocated in the volume bitmap.
Windows has made corrections to the file system.
No further action is required.
470550527 KB total disk space.
334271892 KB in 383367 files.
190368 KB in 89557 indexes.
4 KB in bad sectors.
2100535 KB in use by the system.
65536 KB occupied by the log file.
133987728 KB available on disk.
4096 bytes in each allocation unit.
117637631 total allocation units on disk.
33496932 allocation units available on disk.
Internal Info:
00 bf 1e 00 65 37 07 00 af 24 09 00 00 00 00 00 ....e7...$......
8d 5b 00 00 37 00 00 00 00 00 00 00 00 00 00 00 .[..7...........
Windows has finished checking your disk.
Please wait while your computer restarts.
Thank you for the help
Internal Info:
