Hello, my laptop screen (asus rog zephyrus m 15 gu502gu) after repaste (not liquid metal) does not work anymore. Everything else is fine infact now i am using the pc with the external monitor connected with display port cable.
I think that the problem is the eDP cable that connect the motherboard to display or the eDP connector on the mobo, but i ask here to be sure that isn't something that i'm not thinking about.
Things that i already tried:
Remove the extra ram slot;
Remove the CMOS battery;
Check if the cable connector or MOBO connector are damaged;
Also, i cannot even enter in the bios, probably because the Laptop can enter in it only with dedicate display and when i try to boot into bios windows 10 start automatically, so i assume that there is absolutely no signal to the monitor.
Thank you for the attention.
