Ok so lately my Toshiba laptop, which i have been using to play Wow, had started to stop charging during my game. I first noticed this when i would be playing and get a notice saying my battery has 10% left, and when i look at my lights on the front i would see that it is showing it is plugged in but the battery icon would flash purple instead of orange (charging) or white( full). I would then check my power usage and see that just playing Wow was using 90W, which is 100% of my computers maximum power. I have had this computer for a little over a year so it is past its warranty, and i have never had this problem before, and WoW never used to use that much power. My specs should be more than enough to play wow, because i have a Intel(R) Core(TM) i7-2630QM CPU @ 2.00GHz with 6gb of RAM and a GeForce GT 540M with the 1gb of memory. Even playing wow on low with my computer running in power saver, i still am using 70-80W, which is WAY higher than it should be. I am using the correct power adapter that came with my laptop, and i haven't had a problem with that before either. recently it has started not charging doing low power things as well, such as typing in this forum. If anyone knows why this would be i would appreciate it. My computer isn't getting hot and i have a cooling pad so i do not think components are overheating. The power plug also fits nicely into my laptop and it is not loose, and when it stops charging wiggling the plug doesn't help. It is a Toshiba P750 running windows 7 premium and i have all the latest updates and drivers. I also do not think this is a software issue because i have already reset my computer to factory default to try to fix it, with no luck. Any help would be appreciated, Thanks!
