My thought is that there was some update with respect to drivers and/or configuration.
Are you certain that only one network adapter (wired or wireless) is enabled on the laptop?
On your laptop use the Command Prompt to run "ipconfig /all" (without quotes) and post the results.
Microsoft Windows [Version 6.3.9600]
(c) 2013 Microsoft Corporation. All rights reserved.
C:\windows\system32>ipconfig/all
Windows IP Configuration
Host Name . . . . . . . . . . . . : Arnab
Primary Dns Suffix . . . . . . . :
Node Type . . . . . . . . . . . . : Hybrid
IP Routing Enabled. . . . . . . . : No
WINS Proxy Enabled. . . . . . . . : No
Wireless LAN adapter Local Area Connection* 4:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Description . . . . . . . . . . . : Microsoft Hosted Network Virtual Adapter
Physical Address. . . . . . . . . : EA-86-87-45-E0-8D
DHCP Enabled. . . . . . . . . . . : No
Autoconfiguration Enabled . . . . : Yes
Wireless LAN adapter Local Area Connection* 3:
Description . . . . . . . . . . . : Microsoft Wi-Fi Direct Virtual Adapter
Physical Address. . . . . . . . . : BA-86-87-45-E0-8D
DHCP Enabled. . . . . . . . . . . : Yes
Wireless LAN adapter Wi-Fi:
Description . . . . . . . . . . . : Qualcomm Atheros QCA61x4 Wireless Network
Adapter
Physical Address. . . . . . . . . : B8-86-87-45-E0-8D
Link-local IPv6 Address . . . . . : fe80::d930:f46:a63f:c33%7(Preferred)
IPv4 Address. . . . . . . . . . . : 192.168.31.36(Preferred)
Subnet Mask . . . . . . . . . . . : 255.255.255.0
Lease Obtained. . . . . . . . . . : 19 April 2019 11:13:59
Lease Expires . . . . . . . . . . : 19 April 2019 23:13:59
Default Gateway . . . . . . . . . : 192.168.31.1
DHCP Server . . . . . . . . . . . : 192.168.31.1
DHCPv6 IAID . . . . . . . . . . . : 146310791
DHCPv6 Client DUID. . . . . . . . : 00-01-00-01-1D-1D-B8-46-F0-76-1C-D9-50-7A
DNS Servers . . . . . . . . . . . : 192.168.31.1
NetBIOS over Tcpip. . . . . . . . : Enabled
Ethernet adapter Bluetooth Network Connection:
Description . . . . . . . . . . . : Bluetooth Device (Personal Area Network)
Physical Address. . . . . . . . . : B8-86-87-45-E0-8E
Ethernet adapter Ethernet:
Connection-specific DNS Suffix . : Belkin
Description . . . . . . . . . . . : Realtek PCIe GBE Family Controller
Physical Address. . . . . . . . . : F0-76-1C-D9-50-7A
Tunnel adapter isatap.{B78DF63D-D68E-4E9D-9138-4BA951B96937}:
Description . . . . . . . . . . . : Microsoft ISATAP Adapter #4
Physical Address. . . . . . . . . : 00-00-00-00-00-00-00-E0
