[SOLVED] Laptop Wireless Card compatible with Desktop motherboard?
Yes, unless there is a motherboard limitation. You will still have to wire the antennas to be outside of the case which takes a bezel in the back with two antenna jacks and wiring.
Why not get a USB one instead? And use the m2 for ssd?
I have a wifi card, might as well use it i guess. And there are no antenna jacks anywhere on the motherboard. I was going to ask how do I attach the antennas ?
