The battery being connected to the motherboard on my 2021 ROG Zephyrus G14 prevents it from turning on, even though it is charged. This issue persists even when the laptop is plugged in. However, if the laptop is plugged in with the battery disconnected from the motherboard, it does turn on and function like normal. Before you ask, I did not use metal tools, nor did I drop any screws, and I made sure to disconnect the battery connector evenly and drain the power by holding the power button for 30 seconds before changing any components. I really don't know what could be the issue, considering the motherboard is obviously not fried because the laptop works when only connected to the AC adapter. Has anyone else had a problem like this before? For the life of me, I cannot find any cases of this occurring. I have tried to reseat the battery cable like five times with no different result. For more information, the battery was at 100% when I started all of this, so if that information helps, there you go. Also, when I was first disconnecting the battery, I don’t think I heard any sparks, but when I reconnected it the first time, the laptop worked like normal afterwards, but I did hear some sparks as I was reconnecting it. I then plugged it in and turned it on like normal. For context, it was after that that I thought I had successfully changed the components and booted up Clonezilla to clone a copy of my old SSD onto the new one. But as I thought it was working, I decided to shower, and when I came back, my computer wasn't even showing the charging light when connected to the wall and wasn't turning on regardless. So, that's when I troubleshooted and figured out that it still works if the battery is disconnected. Odd situation. Any help would be appreciated!
