G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi,
I have a problem with my Latitude C400: after gprs software installation
the system crash and if I try to install a new modem or unistall gprs it
appens the same.....
After this network sources too don't work properly, sometimes I can see my
wireless network (only a eth printserver attached on netgear wireless
router ) but if I make double click on the printserver it appears an error
message..."Printserver is not accessible, you might not have the not
permission to use this network resource, contatct the administrator of this
server to find out if you have access permission"(if I do it from another PC
I can see and configure ltp ports and printers)
I'm logged in with administration priviledges, if I try the access using web
browser I can see router and printserver configuration and I can modify all
settings.....
Unluckily I don't have dell recovery cd and I can't restore system to
defaults, If I format the disk I'd lost dell utility link to diagnostic
tools and drivers backup......
Someone can help me?
Thanks
Chris
Hi,
settings.....
Thanks
Chris
