Archived from groups: alt.comp.hardware.pc-homebuilt (
More info?)
Thanks for your suggestion. Could not find anything about disabeling the
onboard
video, so the idea has been scrapped for the moment.
"Dave C." <spammersdie@ahorribledeath.now> wrote in message
news
YWdnT3hL9t5MRrdRVn-uA@comcast.com...
> "Lurker" <hel511@ultrasw.com> wrote in message
> news:108e6s82uhkti4e@corp.supernews.com...
> > We have a Compaq Presario 7465 PC and would like to change out the
> > original Compaq monitor with a Dell LCD monitor.
> > Would someone be kind enough to suggest a video card suitable for this
> > upgrade? I am somewhat concerned about the PCI slot compatibility
> > since the 7465 is pretty old.
> > Thanks in advance,
> First things first . . . don't even think about buying a video card until
> you can confirm that the on-board video of your compaq 7465 can be
disabled.
> But if it CAN be disabled, I'd suggest you try an EVGA GF2 MX400 PCI
format
> card for it . . .
http://www.newegg.com/app/ViewProductDesc.asp?description=14-130-175&depa=0
> I recommended that one as it's cheap, good brand, good quality, and will
> easily support the native resolution of any LCD monitor. There are better
> cards for sure, but I wouldn't recommend spending more money on a PCI
format
> card when even *AGP* format cards are going to be obsolete soon.
> When you buy the monitor, make sure that it has a plain old analog
connector
> on it. It would be nice if it had a DVI connector also, but analog is
> necessary. -Dave
