LCD Monitor
G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
Hi:
My computer is 2 months old.
I just noticed my 19 inch LCD flat panel has a small black spot (the size of
a pin head). Is this normal and/or common?
> size of a pin head). Is this normal and/or common?
Sounds like a dead pixel. Too common, and classed as normal by the
manufacturer - Different manufacturers have different limits on how many
dead pixels equal a dead monitor, but worth calling Dell and asking for a
replacement or repair.
Regards,
Pete.
Derby.
Common with LCD monitors, and the damage is permanent. Most manufacturers
would class a certain number of dead pixels as acceptable, but depending
on their grouping (several dead ones close together for example) may get
you a replacement.
Please add "[newsgroup]" in the subject of any personal replies via email
* old email address "btiruseless" abandoned due to worm-generated spam *
--- My new email address has "ngspamtrap" & @btinternet.com in it ;-) ---
"Chuck Lapre" <chuck@nospam.org> wrote in message
news:fhmbc.7917$NL4.6917@newsread3.news.atl.earthlink.net...
> Hi:
of
Like others here have pointed out, it's likely a "dead pixel", and there's
nothing you can really do about it until enough have accumulated. The
amount of pixel carnage required for action depends upon the manufacturer.
Asking Dell is really the first step though.
As an aside, I'm betting that within a handful of years this is likely going
to be one of those "when things were rotten" things that we look back upon
without fondness. Like: "remember when floppy disks held 36K"? Or
"Remember when Hard Drives used stepper motors instead of voice coils and so
never did an auto-retract when the power went out and thus scraped up the
surface while screaming like a banshee?"
I remember 360k floppies,but not 36k.I also remember 8 inch 80k sssd
floppies too.As for the dead pixels,there have been reported ways to fix
some of them.In my case I use Planar flat panels.They have the best warranty
for replacement,though out of the 3-17" and 2-19" Planars I don't have 1
dead pixel!
"Thomas G. Marshall" <tgm2tothe10thpower@replacetextwithnumber.hotmail.com>
wrote in message news:Noidc.966$d8.261@nwrdny01.gnilink.net...
> > Hi:
size
> of
going
so
Bah. IIRC the 36K floppies were a standard roughly before the 56k floppies.
And when referring to 8", the SD part is moot: It didn't have any bearing
then, it was all just data amounts.
"Douglas" <.> wrote in message news:RfudnTdt_fm2murdRVn-gg@centurytel.net...
warranty
> dead pixel!
> > > Hi:
> size
> > of
there's
manufacturer.
> going
upon
and
> so
the
is it likely that the dead pixel problem will get worse over time?
Worse than dead?
Probably not.
Larry
Allow me to revise the question:
Will 1 dead pixel become many more dead pixels?
Never has on any of my panels.
Tom
news:JRXdc.3290$zj3.2130@newsread3.news.atl.earthlink.net...
Now that's more like it! <g>
It shouldn't. Dead pixels are, for all intents and purposes, a
manufacturing defect that present at the time of manufacturing.
If not already dead, time shouldn't be a factor.
Larry
"Lawrence Glasser" <lglasser@spamcop.net> wrote in message
news:407852DE.C71B4B66@spamcop.net...
That's great to hear! And I *will* report back here about my SDM-X93, but
I've heard that pixels do die over time. Are you sure that this is not so?
