Hey guys,
So I just recently started a build. Here is the Build:
http://ca.pcpartpicker.com/p/TthDf7
I decided to do an out of the case build before I put it in the case to make sure everything was working. Put everything together and pluged in the two power cords to the mobo and one to the graphics card. When power gets to the mobo, a white led is on on the graphics card. When I short the power pins, right next to the power pins a blue light comes on, however the white light goes off. When I stop shorting the power pins it reverses. No screen comes up on screen, no fans start, no sounds come out of the speaker I have hooked up the back of the mobo in the green port.
Has anyone had this problem or know any steps to take to figure it out?
If not where can I get help??? Is there a store somewhere in Torornto???
Thanks,
Mathew
Thanks,
Mathew
