I bought a new Optonica LED driver to power a 5 meter long led strip. I put the 220v cables in and turned the screws tightly. When I plug it in, the power in my house goes off due to a possible short circuit.
How did you determine which wire (red or brown) goes to which screw?
I do not see any markings on the LED driver box to indicate what connections go where.
Do you have an Installation Manual/Guide. Reference link?
Based on some of the diagrams I found it appears to me that you may be connecting the incoming voltage (220) into what should be the LED 12v out connections.
