Simply put, I cannot get this software to work with my LED strips. Armoury Crate will work with my entire system. I am able to do all of the basic lighting effects to my entire system and sync them together. My entire system is running in a static color, rainbow, wave, or whatever preset option Armoury Crate allows. The issue is when I try to go and make custom settings using Aura Creator. It will allow me to work with every piece of my system BUT my LED strips and I cannot figure out why. Whenever I try to single out the LED strips and configure them to do any custom lighting, it just turns all of the lights off. The moment I create anything and hit play, everything just goes black. I've tried reinstalling it several times and using many different versions but I've absolutely no clue what would be the issue. I've done custom lighting effects with every other piece but my LED strips simply refuse to do anything but shut off every single light in the system. Armoury Crate recognizes everything hooked to my system and I've even tried calibrating the strips.
